equipment:kh7050b-laser_cutter [2016/01/28 17:11] wreality |
equipment:kh7050b-laser_cutter [2017/06/26 23:41] wreality |
Line 2: | Line 2: | ||
picture : equipment:kh7050b-laser_cutter:kh-750.jpg# image to use for the tool (don't forget to include namespace if needed) | picture : equipment:kh7050b-laser_cutter:kh-750.jpg# image to use for the tool (don't forget to include namespace if needed) | ||
- | zone : Main floor bar # zone (Woodshop, Machine Shop, Electronics, Crafting, etc) (will be converted to a link to the zone) | + | zone : Laser # zone (Woodshop, Machine Shop, Electronics, Crafting, etc) (will be converted to a link to the zone) |
name : 60 Watt Laser Cutter # Descriptive name for the tool | name : 60 Watt Laser Cutter # Descriptive name for the tool | ||
manufacturer : lcjbdz.com # Manufacturer | manufacturer : lcjbdz.com # Manufacturer | ||
Line 10: | Line 10: | ||
owner : LMN # Owner name (include as a link to a user profile if one exists) | owner : LMN # Owner name (include as a link to a user profile if one exists) | ||
- | status_ : Needs setup # Operational || Needs Repair || Needs Documentation || etc | + | status_ : Operational # Operational || Needs Repair || Needs Documentation || etc |
+ | sop : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing | ||
+ | checkout : Yes | ||
Line 27: | Line 29: | ||
- | * In Addition to the [[zones:shop safety rules]] the following safety rules should be followed: | ||
* [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | ||
Line 34: | Line 35: | ||
* 2015-10-04 limit switch shimmed | * 2015-10-04 limit switch shimmed | ||
* 2015-10-03 E-stop switch replaced after being broken | * 2015-10-03 E-stop switch replaced after being broken | ||
+ | * 2015-12-?? E-stop switch replaced after shorting closed | ||
+ | * 2016-01-18 E-stop switch replaced after melted contact | ||
+ | * 2016-01-?? Power switch replaced with rotary switch similar to what the machine shipped with | ||
+ | * 2016-01-25 Exhaust mounted through window, no longer needs to hang hose out window. | ||
Line 48: | Line 56: | ||
