Both sides previous revision Previous revision Next revision | Previous revision Last revision Both sides next revision | ||
equipment:kh7050b-laser_cutter [2016/02/09 17:11] wreality |
equipment:kh7050b-laser_cutter [2017/04/05 00:38] 127.0.0.1 external edit |
Line 11: | Line 11: | ||
- | sops : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs | + | sop : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing |
checkout : Yes | checkout : Yes | ||
Line 37: | Line 37: | ||
Line 53: | Line 55: | ||
