equipment:kh7050b-laser_cutter [2016/02/09 16:46] wreality |
equipment:kh7050b-laser_cutter [2016/10/27 18:08] wreality |
Line 11: | Line 11: | ||
- | sops : [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing|Laser Cutter SOPs]] | + | sop : https://drive.google.com/folderview?id=0B7VjqKcdj6ztRDZwUmFjUzRnZUk&usp=sharing |
checkout : Yes | checkout : Yes | ||
Line 37: | Line 37: | ||
Line 53: | Line 55: | ||
