equipment:delta-table-saw [2013/09/07 23:23] wreality |
equipment:delta-table-saw [2017/04/05 00:38] (current) |
- | template : :templates:equipment | + | template : templates:equipment |
- | picture_img400 : equipment:deltatablesaw.jpg | + | picture : equipment:deltatablesaw.jpg |
- | zone : woodshop | + | zone : Woodshop |
- | name : Delta 10" Table Saw | + | name : Delta 10" Table Saw |
- | manufacurer : Delta | + | manufacturer : Delta |
- | model : 36-979 | + | model : 36-979 |
- | manual_img : equipment:deltatablesaw36978.pdf | + | manual : equipment:deltatablesaw36978.pdf |
- | owner_page : user:carlraymond:start | + | memberlevel : Full |
- | status_ : working | + | owner : [[user:carlraymond:start|Carl Raymond]] |
+ | type : Table Saw | ||
+ | status_ : Operational | ||
+ | checkout : | ||
+ | ===Description=== | ||
+ | ===Safety Rules=== | ||
+ | ===Maintenance Log=== |
