Both sides previous revision Previous revision | Next revision Both sides next revision | ||
equipment:delta-table-saw [2016/02/08 20:13] wreality |
equipment:delta-table-saw [2016/02/08 20:14] wreality |
Line 15: | Line 15: | ||
The table saw is a woodworking tool consisting of a circular saw blade, mounted on an arbor, that is driven by an electric motor. The blade protrudes through the surface of the table, which provides support for the material, usually wood, being cut. The depth of the cut is varied by moving the blade up and down: the higher the blade protrudes above the table, the deeper the cut that is made in the material. The angle of cut is controlled by adjusting the angle of blade. | The table saw is a woodworking tool consisting of a circular saw blade, mounted on an arbor, that is driven by an electric motor. The blade protrudes through the surface of the table, which provides support for the material, usually wood, being cut. The depth of the cut is varied by moving the blade up and down: the higher the blade protrudes above the table, the deeper the cut that is made in the material. The angle of cut is controlled by adjusting the angle of blade. | ||
+ | * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztb0Q1bG5rMUUyMG8&usp=sharing|SOPs]] | ||
In addition to the [[zones:shop safety rules]] the following should be observed while using the table saw. | In addition to the [[zones:shop safety rules]] the following should be observed while using the table saw. | ||
Line 43: | Line 49: | ||
* The fence must not be adjusted while the saw is running. | * The fence must not be adjusted while the saw is running. | ||
* While long stock is sometimes crosscut on a table saw, it is not a good practice. The long stock may interfere with other operations and may be a hazard to other workers or equipment. It is also difficult to support and is better cut on a mitre saw or radial arm saw. | * While long stock is sometimes crosscut on a table saw, it is not a good practice. The long stock may interfere with other operations and may be a hazard to other workers or equipment. It is also difficult to support and is better cut on a mitre saw or radial arm saw. | ||
- | ===Contacts for Training=== | + | |
- | * Contact [[user:wreality:start|Brian Adams]] or [[user:carlraymond:start|Carl Raymond]] for training. | + | |
- | * [[https://drive.google.com/folderview?id=0B7VjqKcdj6ztb0Q1bG5rMUUyMG8&usp=sharing|SOPs]] | + | |
* Review of machine and shop safety rules. | * Review of machine and shop safety rules. |
