equipment:delta-table-saw [2013/09/07 23:44] wreality |
equipment:delta-table-saw [2016/02/09 17:15] wreality |
Line 7: | Line 7: | ||
model : 36-979 | model : 36-979 | ||
manual : equipment:deltatablesaw36978.pdf | manual : equipment:deltatablesaw36978.pdf | ||
- | membership_level : Full | + | memberlevel : Full |
owner : [[user:carlraymond:start|Carl Raymond]] | owner : [[user:carlraymond:start|Carl Raymond]] | ||
type : Table Saw | type : Table Saw | ||
+ | checkout : | ||
+ | ===Description=== | ||
+ | ===Safety Rules=== | ||
+ | ===Maintenance Log=== |
