equipment:delta-table-saw [2013/09/07 23:32] wreality |
equipment:delta-table-saw [2016/02/09 17:15] wreality |
Line 2: | Line 2: | ||
picture : equipment:deltatablesaw.jpg | picture : equipment:deltatablesaw.jpg | ||
- | zone : woodshop | + | zone : Woodshop |
name : Delta 10" Table Saw | name : Delta 10" Table Saw | ||
manufacturer : Delta | manufacturer : Delta | ||
model : 36-979 | model : 36-979 | ||
manual : equipment:deltatablesaw36978.pdf | manual : equipment:deltatablesaw36978.pdf | ||
- | owner_page : user:carlraymond:start | + | memberlevel : Full |
- | status_ : working | + | owner : [[user:carlraymond:start|Carl Raymond]] |
+ | type : Table Saw | ||
+ | status_ : Operational | ||
+ | checkout : | ||
+ | ===Description=== | ||
+ | ===Safety Rules=== | ||
+ | ===Maintenance Log=== |
