equipment:buildlog_laser_cutter [2014/12/15 23:24] tim |
equipment:buildlog_laser_cutter [2014/12/15 23:32] tim |
Line 40: | Line 40: | ||
There are several ways to command the laser to fire: | There are several ways to command the laser to fire: | ||
- | - G0 / G1: enabled by the LASER_FIRE_G1 option in Configuration.h, G0 moves the laser to a specified set of coordinates **without** firing, a G1 command moves the laser to the specified coordinates **while** firing. | + | * G0 / G1 (**default: on**): enabled at compile time by the LASER_FIRE_G1 option in Configuration.h, G0 moves the laser to a specified set of coordinates __without__ firing, a G1 command moves the laser to the specified coordinates __while__ firing. |
- | - M3 / M5: enabled by the LASER_FIRE_SPINDLE option in Configuration.h, M3 turns the laser on in place, without requiring it to move. M5 turns the laser off in place. | + | |
- | - E movements: enabled by the LASER_FIRE_E option in Configuration.h, any movement in the E axis (which represents the extruder when controlling a 3D printer) fires the laser. In this way, the laser can make use of unmodified g code generated for 3D printers. | + | * M3 / M5 (**default: on**): enabled at compile time by the LASER_FIRE_SPINDLE option in Configuration.h, M3 turns the laser on in place, without requiring it to move. M5 turns the laser off in place. |
+ | * E movements (**default: off**): enabled at compile time by the LASER_FIRE_E option in Configuration.h, any movement in the E axis (which represents the extruder when controlling a 3D printer) fires the laser. In this way, the laser can make use of unmodified g code generated for 3D printers. | ||
Each of these firing controls accepts the following parameters, which can also be manipulated without firing or moving the laser by using them with the M649 command: | Each of these firing controls accepts the following parameters, which can also be manipulated without firing or moving the laser by using them with the M649 command: |
