equipment:8in-drill-press [2014/05/10 20:05] wreality |
equipment:8in-drill-press [2017/04/05 00:38] (current) |
Line 16: | Line 16: | ||
- | **This drill press has a badly frayed belt. Carl is in the process of trying to locate a new belt.** | ||
A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. | A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. | ||
Line 39: | Line 38: | ||
===Maintenance Log=== | ===Maintenance Log=== | ||
+ | * 5/2014 - [[user:carlraymond:start|Carl Raymond]] replaced the drive belt. |
