equipment:8in-drill-press [2014/05/10 20:05]
wreality
equipment:8in-drill-press [2017/04/05 00:38] (current)
Line 16: Line 16:
-**This drill press has a badly frayed belt.  Carl is in the process of trying to locate a new belt.**
 A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically.
Line 39: Line 38:
 ===Maintenance Log=== ===Maintenance Log===
 +  * 5/2014 - [[user:​carlraymond:​start|Carl Raymond]] replaced the drive belt.
