equipment:8in-drill-press [2014/05/10 20:04] wreality |
equipment:8in-drill-press [2017/04/05 00:38] |
- | picture : :equipment:8in_drill_press.jpg | ||
- | zone : Machine Shop | ||
- | name : 8 inch Central Machinery Drill Press | ||
- | manufacturer : # Central Machinery | ||
- | model : # 44506 | ||
- | manual : # :equipment:44506.pdf | ||
- | memberlevel : # Full | ||
- | owner : # Tim Schmidt | ||
- | type : # Drill Press | ||
- | status_ : # Operational | ||
- | ===Description=== | ||
- | A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. | ||
- | ===Safety Rules=== | ||
- | In addition to the [[zones:shop safety rules]] the following rules should be followed. | ||
- | * A two foot perimeter around the drill press should be kept clear of people, debris and sawdust that impair traction or footing to avoid slips and falls. | ||
- | * Safety glasses with side shields or a face shield must be worn. Hearing protection should be worn. | ||
- | * Remove loose fitting clothing, jewelry, and tie back long hair. | ||
- | * Give the work your undivided attention. | ||
- | * Do not wear gloves or anything that would allow a hand, fingers or clothing to be wrapped around the revolving bit. | ||
- | * Tim Schmidt | ||
- | * Brian Adams | ||
- | * Carl Raymond | ||
- | * Review of machine and shop safety rules. | ||
- | * Proper procedures for preparing / setup operations. | ||
- | * Proper operation and control of machine. | ||
- | * Proper procedures for cleanup. | ||
- | ===Maintenance Log=== |
