equipment:8in-drill-press [2014/05/10 20:04] wreality |
equipment:8in-drill-press [2014/05/10 20:05] wreality |
Line 4: | Line 4: | ||
zone : Machine Shop | zone : Machine Shop | ||
name : 8 inch Central Machinery Drill Press | name : 8 inch Central Machinery Drill Press | ||
- | manufacturer : # Central Machinery | + | manufacturer : Central Machinery |
- | model : # 44506 | + | model : 44506 |
- | manual : # :equipment:44506.pdf | + | manual : :equipment:44506.pdf |
- | memberlevel : # Full | + | memberlevel : Full |
- | owner : # Tim Schmidt | + | owner : Tim Schmidt |
- | type : # Drill Press | + | type : Drill Press |
- | status_ : # Operational | + | status_ : Operational |
+ | **This drill press has a badly frayed belt. Carl is in the process of trying to locate a new belt.** | ||
A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. | A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. | ||
===Safety Rules=== | ===Safety Rules=== |
