equipment:8in-drill-press-woodshop [2017/04/05 00:38] |
equipment:8in-drill-press-woodshop [2017/04/05 00:38] (current) |
+ | ---- datatemplateentry equipment ---- | ||
+ | template : templates:equipment | ||
+ | picture : :equipment:8in_drill_press.jpg | ||
+ | zone : Woodshop | ||
+ | name : 8 inch Central Machinery Drill Press | ||
+ | manufacturer : Central Machinery | ||
+ | model : 44506 | ||
+ | manual : equipment:44506.pdf | ||
+ | memberlevel : Full | ||
+ | owner : Tim Schmidt | ||
+ | type : Drill Press | ||
+ | status_ : Operational | ||
+ | ===Description=== | ||
+ | A drill press is a fixed style of drill that may be mounted on a stand or bolted to the floor or workbench. A drill press consists of a base, column , table, spindle, and drill head. The head has a set of handles radiating from a central hub that, when turned, move the spindle and chuck vertically, parallel to the axis of the column. The table can be adjusted vertically. | ||
+ | ===Safety Rules=== | ||
+ | In addition to the [[zones:shop safety rules]] the following rules should be followed. | ||
+ | * A two foot perimeter around the drill press should be kept clear of people, debris and sawdust that impair traction or footing to avoid slips and falls. | ||
+ | * Safety glasses with side shields or a face shield must be worn. Hearing protection should be worn. | ||
+ | * Remove loose fitting clothing, jewelry, and tie back long hair. | ||
+ | * Give the work your undivided attention. | ||
+ | * Do not wear gloves or anything that would allow a hand, fingers or clothing to be wrapped around the revolving bit. | ||
+ | ===Contacts for training== | ||
+ | * Tim Schmidt | ||
+ | * Brian Adams | ||
+ | * Carl Raymond | ||
+ | * Proper procedures for preparing / setup operations. | ||
+ | * Proper operation and control of machine. | ||
+ | ===Maintenance Log=== |
