equipment:buildlog_laser_cutter [2014/12/15 23:26] tim |
equipment:buildlog_laser_cutter [2016/01/28 17:59] wreality |
Line 4: | Line 4: | ||
Line 12: | Line 12: | ||
owner : [[user:tim:start|Timothy Schmidt]] # | owner : [[user:tim:start|Timothy Schmidt]] # | ||
type : Laser Cutter# Generic name of the tool (Table Saw vs. 10" Contractor Table Saw) | type : Laser Cutter# Generic name of the tool (Table Saw vs. 10" Contractor Table Saw) | ||
- | status_ : Operational # | + | status_ : No Longer at LMN # |
Line 39: | Line 39: | ||
- | - G0 / G1 (default: **on**): enabled by the LASER_FIRE_G1 option in Configuration.h, G0 moves the laser to a specified set of coordinates **without** firing, a G1 command moves the laser to the specified coordinates **while** firing. | + | * LASER_FIRE_G1 (**default: on**): G0 moves the laser to a specified set of coordinates __without__ firing, a G1 command moves the laser to the specified coordinates __while__ firing. |
- | - M3 / M5 (default: **on**): enabled by the LASER_FIRE_SPINDLE option in Configuration.h, M3 turns the laser on in place, without requiring it to move. M5 turns the laser off in place. | + | |
- | - E movements (default: **off**): enabled by the LASER_FIRE_E option in Configuration.h, any movement in the E axis (which represents the extruder when controlling a 3D printer) fires the laser. In this way, the laser can make use of unmodified g code generated for 3D printers. | + | * LASER_FIRE_SPINDLE (**default: on**): M3 turns the laser on in place, without requiring it to move. M5 turns the laser off in place. |
Line 117: | Line 119: | ||
